Originally Posted by
aehaas
How does one use the telemetry with a DX18 transmitter?
AEHaas
All I can say is the direct connection cable would not work with Jeti as the sensor list is not populated on switch-on. No biggie, just used the JC telemetry adaptor with the ribbon cable and all is well. You may have more success with Spektrum! Interestingly, if I configure initially with the adaptor and then connect directly it will read the data stream, until the next power off/on cycle.
