Originally Posted by
Hydro Junkie
I would just replace the pieces supplied with a new piece wide enough to cover the entire leading edge, height wise. After that, a small block plane or belt sander would be used to take off a majority of the extra balsa prior to the final sanding. This would eliminate the chance of any hard spots that could result from adding additional material to the supplied pieces
I used good ol' Titebond wood glue, which sanded easily enough for shaping. I keep moving further and further away from CA on every build.
