Originally Posted by
speedracerntrixie
Looks like you could safely with some aluminum servo arm increase the servo arm to 1” and get more throw. That is provided you have throw maxed out in the TX. Also if you have dialed in a bunch of expo it will seem to slow rate down a bit. .18 servo speed is a bit on the sluggish side as well.
You suggested in one of your earlier posts of increasing the wing positive incident by 1/16", what would that equate to in degrees, about 1.5 degrees ?
