Originally Posted by
Jeffryz
Well I finally completed changing out all the electronics and motor. I measured the CG at 4.5" from the top wing LE, however..... hanging the plane by the top wing causes it to hang like a pendulum. So that does not seem like a good way to indicate the CG. What is the correct way to balance the plane to measure the CG?
Jeff if you go back to page 409 post 10201 Bill (stickbuilder) gives the proper way to find the CG hope this helps
http://www.rcuniverse.com/forum/gold...o-ymf-409.html
