Originally Posted by
Jeffryz
Thanks Dan. It looks like you supported the plane with the vertical dowels on the underside of the wing. What did you use reference as the "level line" on the plane?
Tx JJ
JJ the datum line is were you want the plane to be level when balancing the plane. Hope this picture helps
