RE: CF wing tube installation???
don't have pictures....
easy setup...once the wing tube is drilled to accept the screws.....
#1 wood dowel that fits inside the wing tube...cut off two lengths of dowel 1/2" long
#2 Drill the wooden dowels on the side of the cylinder not the face to accept a 3/4" long piece of nyrod pushrod material.
#3 Fit this dowel assembly into the wing tube.
#4 use a #4 sheet metal screw and washer to secure the dowel assembly in the tube for glue. This is done through the hole drilled in the wing tube to accept the screw from the wing panel...Note the tube is not inside the wing at this point.
#5 Epoxy or CA the dowel inside the tube.....Once glue is dry remove #4 sheet metal screw and washer.
#6 Its done put the tube inside the wing and install a #4 sheet metal screw into the tube through the wing panel.
Should not need a picture of it...its only a slice of dowel 1/2" long with a hole in it. Then a little piece of yellow plastic pushrod material 3/4" long
