Klotz Super Techniplate Is the one with the castor oil additive? If so, I would caution against using that, and I speak from experience, it gummed up one of my engines pretty good. I believe the the ‘burn point’ of castor makes it turn to carbon pretty quickly.
indont want to start the “oil” discussion/debate but I don’t think that’s a good option. Use redline or stihl ultra instead.
the HS needle will get to around 7 turns out if I recall. Read up earlier in this thread about rotating the engine when running in. It will not fire properly on the lower cylinders as they run so rich they don’t fire.
use the standard pipes on it while running in, then you can see which ones aren’t firing, they just spew oil and smoke.
