Hi,
What is the arched pieces on underside for?
To tilt the transmitter slightly while resting on the ground?
To give more room for the side levers to the ground so less risk they do not alter position when transmitter sit on the ground?
I see no support points in lower end of backside of transmitter - does the transmitter rest on ground on the alcantara leather there?
If so, will it not be wear and tear on the alcantara leather on those resting points when transmitter is sitting on the ground?
/Bo
