K80G v1 doesn't get to max rpms
I got the engine with 3hrs, it was mounted on a glider before, I run the engine recently to full throttle and down one click per second two times, idles is good, throttle response is good but max rpms is only up to 142,500 with a PW of 310, using a new 4K mah LIFE batt, run Kero for first and second run, will be using Diesel next time, max rpms is programmed to 145K and pump limit is set to 340.
Is there a way to rest the throttle loop.
Thanks in advance.
