Worked on building the rudder. I decided to try Airex as a foam sandwich material on the skins.
I laser cut the foam and included a 15mm spacing grid of 1mm diameter holes to serve 2 purposes; 1) to prevent any trapped air bubbles & 2) to provide a mechanical bond of epoxy between both sides.
The Airex was easily formed around the leading edge radius with some gentle application of hot air from a heat gun, and when cool it took the necessary set to hold the shape.Otherwise the skin construction followed my normal method, using Klass Kote Epoxy primer first in the mold, a surfacing layer and then 9oz glass cloth, Airex and another layer of glass. This was then vacuum bagged overnight. Once cured, the excess glass was trimmed. Surface detail looked good. The inner structure was laser cut and assembled. Bonding was achieved with thickened epoxy.
Paul
