Not sure this engine has a high compression ratio. Has anyone ever measured it? Otherwise I would do it the next time this engine is on the bench. Remember that the valve blocked in open position did not touch the piston. So there is still some room...
But the issue of detonation is in my opinion rather related to the too important timing (up to 52 ° before TDC on 1 cylinder) on this engine.
JM
