RCU Forums - View Single Post - Taigen JS-2 initial impressions
Old 04-02-2019 | 01:20 AM
Dusty Steppes
Originally Posted by Lotuswins
Tanks for the preview Dusty. Mine is to arrive on Wednesday, I hope.
Too bad about the damage, I hope mine fares better.
Did the tank come with the leads to connect a hobby grade receiver? Just curious, though I do have a set from a defunct V2 MFU.
Are the sounds appropriate for the JS2?? I will be experimenting with an aftermarket speaker just to see if it gets better.....can't wait!!
Jerry Rude
The damage was minor, more than likely caused by the shipper as it was all on the left side of the tank and one side of the box had some damage.
It did come with leads and a jumper for using a hobby grade radio. The instructions describe 6 channels
1 steering
2 throttle
3 firing/elevation
4 turret rotation
5 engine on/off
6 main mother trim
Nothing is listed about the machineguns or smoker on/off. If these require another two channels there is no way to connect them and if these are done with channel mixing there is no mention of it.
If connectivity is required why is it not provided and if mixing is needed what channel mixing gives you the results are questions that need to be answered.
The sounds are a vast improvement over the earlier sounds that Taigen used. I would say the quality is pretty close to, if not as good as a TK22.
I do strongly recommend inspecting the transmissions to make sure no wires or components are touching the gears and that power leads on the motors are not shorted against the neighboring transmission. It is a very tight fit in the rear of the tank.
