Originally Posted by
Quikturn
OK. I finally got the lower end disassembled today. The drive washer was real stubborn to get off. Normally 2 jaw pullers and some heat due the trick but I ruined my el-cheapo puller in the process so I used heat on the drive washer and lightly hammered the crankshaft out. The crankshaft cleaned up real nice but I did find some light pitting in a spot in front of the main bearing. Took a wire wheel to it to smooth it out so I’ll go with it.
Quick, Dan turned me onto this puller at Amazon.com.
Posi-Loc 102, by screwing the lower handle down firmly tightening the jaws into the prop driver, it will not damage the prop driver.
https://www.amazon.com/Posi-Lock-Man...s%2C168&sr=8-1
