Originally Posted by
didiwatt
For those using Electron gear, the factory said the nose gear steering plate is made for a Hitec HS225.
They are only rated for 6v. My system is high volt. I cant seem to find a high volt replacement. The 225 measures 32.4x16.8x30.8mm. Anybody else find a good HV sevo to fit.
I hate to file the aluminum plate for a larger servo as you have pre drilled and threaded holes.
Hi,
Just ask Electron for a servo plate fitting your 15 or 16 mm servo of your choice. I use a Graupner HBS660 HV Servo for steering, and fits perfectly in the servo plate for 16 mm servos.
