If anyone is asking about the wheel wells I used cardboard from the box that you buy a pack of soda. If you take your time the cardboard will be cut to fit from the surface of the sheeting down to the other side of the sheeting. Monokote does stick to the cardboard and then when you fuel proof the wheel wells you then glue down the covering. I will post pictures of the final look here shortly.
