RCU Forums - View Single Post - OS 15LA Fueling Problem
Old 04-07-2019 | 06:22 AM
aspeed's Avatar
aspeed
Sounds like you covered everything already. Smaller motors like to idle a bit higher than larger ones. You shouldn't expect a 2,000 rpm idle. Other than that, an airbleed carb screw is clockwise rich CCW lean. opposite of normal. I am sure you know that. Is the tank close to the motor?
