16 sz switch programming
As a long time Futaba user WC1 WC2 and other marks of Futaba im at a loss !!!!!!!!!!!!!
Gents could some one please assist with the following in simple terms
All i am trying to do is turn on my ignition circiut using a simple rexcell ignition switch
in function position 8 motor switch SG selected GR- trim nil GR motor reversed
3 position switch in this case S/G
1st foreward position OFF SAFE
2 nd Middle position OFF SAFE
3rd back position ON RUN
I can see the switch changing state using servo monitor AND the LED changing state
The first position 1 led indicator off ignition off - SPOT ON endpoint @ 100%
Middle position 2 SHOULD be OFF its ON - Wrong !! servo monitor is showing middle position i belive to be 0 setting middle point
3 rd back position is ignition led ON - SPOT ON endpoint @30%
In AFR page FUNCTION selected - Motor selected Group GR
i have tried to move the centre point to acheive a 30%-40% figure to move the middle point but the switch will not turn OFF in the middle
although the switch is correct when activated OFF-OFF-ON
i have tried all combinations spline point exp2 expo1
I just dont know were im going wrong
Ive set every thing else up works great BUT these dam switches are driving me MAD as we say in the UK im buggerd if i know !!!!!!!
Kind Regards to all
Dave
UK
