Well, you're in the Diesel section so a suppose you're looking to fuel a model diesel engine. If so, model Diesel engines are typically pretty small, and because they are quite fuel efficient, they often have small fuel tanks.
With the above in mind, I usually use a Sullivan fuel bulb.
S171 ? Gasoline Bulb Pump 6oz. ? Sullivan
