Receiver Specifications:
Model
IV006 V4(DVR)
DVR Function
VR with auto save function
Working Voltage:7-26v
Power Consumption:12V,210mA
Channel:64CH (RaceBand)
Format:NTSC/PAL selectable via menu
Sensitivity:=-95db
Channel Selection
igital Display, Single Button Selection, Auto Scan, Diversity
Antenna Connector:SMA- Jack (outer thread, inner hole)
DIV006 Features:
DVR recording audio and video signal simultaneously in D1 resolution.
AV out:640x480
Video compression format:MJPG
TF card slot, support to 64GB
Recording file format:AVI
Playback available
PAL/NTSC selectable via menu.
48CH selection by single button, digital display current channel#.
Single short press button to change channel from CH1 to 8 and buzzer beeps while each press; long beep indicates on CH1.
Each time long press 3s to change band from A to H.
Digital tube point indicates which antenna is selected to work.
Receiver Accessories:
1x5.8G A/V Receiver
2x5.8G antenna
1x1.2m, 3.5male/RCA male AV cable
1x1m, 2.1*5.5male/bare tin power cable
1x30cm, 3.5male/RCA female AV cable
Browse through the details of the merchandise:
https://www.aliexpress.com/item/Amow...969385936.html
