For those who have not played with the MPDX menu's .........
Example of selecting channels 11 & 12 for MPDX use ........
Then we can select what we want to control each of the Multiplexed outputs from ........
Then go into the ATV menu and this will appear ...........
Now you can adjust the travel of each output ........
If you need to reverse any of them, this can be done by reversing the switch operation in the H/W Reverse, in the System Menu.
You cannot use them into any of the mixers or set any failsafes for these in the transmitter - failsafe is set on the MPDX Decoder itself.
modtron
Oxford UK
