Hi again,
Thanks for the detailed explanation. Yes I thought that kevlar was a better option but I suppose it was worth the try in using peel ply. Another point I wish to asked is the use of the honeycomb material. I always shy away from this material as I am not experienced at all in using it since I mainly use Airex foam. Presumably you may be using the thin version 1mm or so but when you vacuum bag the honeycomb will it leave a wavy surface and won't it leave too much resin between hexagon?
Thanks again for putting up with my questions!
Reuben.
