Originally Posted by
marksp
Question regarding fuel pump setup - after installing fuel pump I removed tube from air pump to carb bladder and installed a festo cap (see picture). Question is, what to do on carb end?
Attachment 2264027
I plugged the carb hole with a short 4 mm screw. Left tube open from the air pump. Very little grease leaking from the open tube. No problems after many hour of run time.
J Tab
