RCU Forums - View Single Post - Jeti DS-24
Thread: Jeti DS-24
Old 05-06-2019 | 01:00 PM
  #1285
Custmachr
Originally Posted by hk3957w
yes that’s exactly my configuration. I updated all receivers and CB200 to last version, Two 2.4 into CP to CB200 R1 and R2 and the 900 directly into CB200 ext port (receiver config selected in CB) actually testing in avanti ducted fan. working flawlessly. next step is using in the turbinator 2 with more telemetry (turbine and speed sensor) and 40 cm extension for receivers. thanks danny for the info
Do you have the switchover strategy set to time out or to mixing?? It appears in the update notes you cannot use mixing with the assist so I would assume that would be true with the CP as well??
Tim
