Originally Posted by
Custmachr
Do you have the switchover strategy set to time out or to mixing?? It appears in the update notes you cannot use mixing with the assist so I would assume that would be true with the CP as well??
Tim
hi tim, I checked in the radio is time out (80ms) I told with james from esprit tech about that (he say it depends how is your signal if you have strong signal and Q value time out is OK but mixing is little bit slow but better stability) so I have RX1 A1 A2 minimum 5 RX2 minimum 5 Q value 100% in both receivers all time time out 80ms, with this I am testing in avanti ducted fan flawlessly.
about extension between cb / cp / rx don’t use more that 20 inches or 50 cm. 2 extensions per receiver so I will go with power box cable 1 extension of 25 cm and the second one with 25 and test it in the avanti.
have a great day
