RCU Forums - View Single Post - Jeti DS-24
Thread: Jeti DS-24
Old 05-07-2019 | 06:53 PM
  #1290
Custmachr
Originally Posted by hk3957w
hi tim, I checked in the radio is time out (80ms) I told with james from esprit tech about that (he say it depends how is your signal if you have strong signal and Q value time out is OK but mixing is little bit slow but better stability) so I have RX1 A1 A2 minimum 5 RX2 minimum 5 Q value 100% in both receivers all time time out 80ms, with this I am testing in avanti ducted fan flawlessly.
about extension between cb / cp / rx don’t use more that 20 inches or 50 cm. 2 extensions per receiver so I will go with power box cable 1 extension of 25 cm and the second one with 25 and test it in the avanti.
have a great day
Tim
