Originally Posted by
Bobneal1
Tom,
If you loaded this particular jet into the DS -24 from another Jeti radio and the layout was different then you will get this message. If the other jets were installed from scratch on the DS -24 then they would not show this. Check the functions menu on the jet that is giving you the error message and make sure you have the right switches controlling the functions as you want them. I had the same problem switching from the 16 to the 24.
Bob
Thanks for info Bob. I did not load this jet from another Jeti radio, I built it from scratch in this radio. However, I think I built it from scratch
before I changed out the switches, which could probably cause the same issue you describe above. On a hunch, I changed the switch assignment on each of the three switches I had changed out, then turned off the transmitter, thus saving the config. I then turned it back on and reassigned the functions back to the new switches and that seems to have cleared up the issue.
Thanks again for the help! - Tom
