I was able to remove the aileron and flap servo screws without too much trouble. The good part is I do not need to replace the mounting rails. Today I have #4 x 3/8" wood screws arriving. Next I will countersink the screws into the aluminum mounts by using a larger drill bit. Once servos are installed I will install the flap and aileron control horns. Should have wings completed by tomorrow with all controls hooked up. This will complete all the control hook-ups.
Most of the steps left to complete:
1. Plumb and install UAT and fuel tanks
2. Plumb air supply for gear and brakes
3. Create electronics board and install components
4. Program and test landing gear and gear door sequence
5. Paint pilots
6. Assemble cockpit with pilots and install
7 Install batteries for best balance
8. Adjust all controls and Cortex Pro
The list is getting shorter and I should have it completed in the next couple weeks dependent on work schedule.
