I have set up a program for my tug plane (ailerons and flaps - 4 servo wings), in my new Taranis X9D Plus flashed with OpenTx 2.2.2.
I have both servos operating ok.
I entered two lower rates in the aileron channel #1 in the mixer and the result is as it should be: the ailerons function accordingly. (resulting in triple rates).
However, I did not enter the same two lower rates lines into Channel #7 which is my left aileron.
The output of channel #7 (left aileron) is the same as that of channel #1 (right aileron). (Corrected below).
How does this occur when I have yet to enter the second and third lower rates lines into channel #7?
Is this an automatic function as a result of choosing it in the set up wizard?
Jim.
Edit:
What I have posted above is wrong. The two ailerons
do not move the same deflection on the lower rates, as I have programmed above.
It appears that it would be best practice to put the two lower rate lines in the aileron inputs and not the mixer.
Correct?
