Originally Posted by
Jim.Thompson
I am correct in translating that to mean that MAX can be used as in input to the mixer?
Jim.
You can - you can use MAX directly as a source in the Mixer. Or you can use it in Inputs first, where it gets modified with different rates, before being passed on to the Mixer. I do that with flaps generally - use MAX with rates controlled by a switch, rather than use the switch itself as an Input source. Less confusing to my weak mind when I try to keep track of what values are being passed along.
