Brison 5.8 problems
Hello all. Recently got my old 5.8 off the shelf after about 4 years and converted to electronic ignition. Removed all mechanical advance and Set the timing at 30 degrees and new carb (WJ-71). With low needle at .75 out and high the same. Checked the timing again to make sure.
Ive attempted to start this thing for 2 weeks now, with same results every time. Eventually each time i try to start, the plug is soaked. I have fire, I have gas, but not even a hint of it trying to hit.
Anyone know about these engines or ever had this problem? At first, i was sure it was a timing issue. ive probably checked it a dozen times and its right on the money. even with the spark plug out and watching, it fires where its supposed to - just past the sensor on 30 exactly.
im stumped.
