Originally Posted by
tedsander
You can - you can use MAX directly as a source in the Mixer. Or you can use it in Inputs first, where it gets modified with different rates, before being passed on to the Mixer. I do that with flaps generally - use MAX with rates controlled by a switch, rather than use the switch itself as an Input source. Less confusing to my weak mind when I try to keep track of what values are being passed along.
Thanks for that explanation Ted.
I have yet to understand how a "switch" can function as an input source.
Can you explain for me please?
Jim.
