Originally Posted by
tedsander
Jim - I didn't take you for a raw beginner, given your shown ability to use Companion, and the level of what you have already done. Hence "compressing" the explanation on my part. I also incorrectly assumed that you might experiment by duplicating the examples given in Companion (and that you were advanced enough to not need shots of the mixing tab to get it all to work), and seeing how each variation works in the simulator.
My post above were also just screenshots of one part of a setup to illustrate what was applicable to the question about inputs. In my case, I used the "Windows Snipping Tool" to make the screen shot. .......................
Ok, my screenshots were done with the Linux Mint screenshot tool.
If this works, save your file, rename it, and attach it in a response. I'd be glad to edit it, and then discuss what changes I made, and why.
Ok. I have done that. Thanks. Lets see if my post with the attached file works.
Jim.
