Originally Posted by
tedsander
Probably not playing well with Linux. Haven't heard about any widespread issues like that. You may need to research it a bit on RCGroups, or openrcforums.
Yes Ted. That is likely the problem.
I will try opening Companion in my old Win7 partition, which I still use offline, and give a go from the beginning again.
There is a good outcome as a result of all this hassle; I am learning to enter the correct (I think) parameters. I have to do it countless times before it stablises.
I will post a file of a partly done tug plane set up.
It will have only basic functions; I will omit the engine cut (kill) switch and the aerotow release for the time being. I have lost count of the number of times I have attempted to do so, only to lose everything and have to go back to Line #1!
However, that is also ok. It will provide me/you with a good look at the tripple rates, the input window and the mixes and allow you to check if I have done them correctly so far.
If and when that is satisfied, I will move onto entering the release and cut lines.
Better days ahead.
Jim.
