Looking for Flameout Alarm setup suggestions
What’s the best parameter or parameters to use when programming a telemetry alarm for a flameout….RPM, EGT, pump voltage?...and what values? Also, is there a way to do it so the alarm does not go off before startup because if not, it would need to be canceled and then reset somehow after start.
I’m using a Jeti DS-24 transmitter but I’m thinking whatever setup is best can probably be programmed with most modern radios. Looking for suggestions.
Craig
