RCU Forums - View Single Post - Beginner to Gas
Old 06-14-2019 | 07:34 AM
kmeyers's Avatar
kmeyers
Originally Posted by ahicks
I see this is your first post, so first things first. Welcome to RCU, and welcome to gas!
Second, I think many of us will agree, especially when talking about the size plane that will likely be found with a 10cc gasser in it's nose, that one battery will do just fine - and there's no need for it to be something huge either. The ignition module won't use much more than a servo would.
If you are buying a new battery, I would HIGHLY recommend you seriously consider a battery with LiFe chemistry. They have proven very reliable, user friendly, and they can deliver the "punch" needed to run an entire flight pack, plus ignition with no struggle.
I second this as great info. When 1 battery is being used we rely on an IBEC (Ignition Battery Eliminator Circuit). This isolates the radio from ignition noise and provides an extra engine cut off feature. All new IBEC will come with a set up info.
welcome back and happy landings.
