RE: Nitro engine leaking?
sounds like you back plate is a little loose.... take off the pullstarter, take the back plate off and put a little Sensor Safe RTV sealant around it, and bolt it back on.... do the same with the carb... a little RTV where the carb meets the motor, and you should be ok!
