RCU Forums - View Single Post - Mounting a pull pull arm to a Hitec 7955 servo wheel
Old 06-16-2019 | 05:39 PM
speedracerntrixie's Avatar
speedracerntrixie
My Feedback: (29)
Sounds like you have a grip on the geometry, that was my concern. Back to the splines, the HD black Hitec servo wheel may work for what you have in mind. The way I would do it is with some .062 aluminum or CF but do a double arm having one on the bottom of the wheel and one above and put a ball link between the two. This would load the servo output shaft more evenly so that the load is not concentrated on the upper half of the splines.
