Originally Posted by
Hobbsy
I wish I had some easy peazy way to check the pressure tap to see if it actually works. I'm cyphering on it hopefully without harming my brain. I think a simple balloon would show me something.
It's easy to make a manometer with an 10 ft. piece of clear vinyl tubing clamped to a board or a wall. Conversion from inches of water column to psi is easy with online calculators. I watched a couple of youtube vids and made one, took about 15 minutes. Alternatively you can purchase a 1-5 psi pressure gauge which is less accurate and more expensive but more convenient to use.
I'm wondering if the the location you chose to put the pressure nipple on your Keleo ring is going to quickly burn out the silicone tubing. It's got to be very hot directly across from the header.
