RCU Forums - View Single Post - Vortex F3A build thread
Old 06-23-2019 | 09:51 AM
Alex Voicu
Originally Posted by Krille
What is the dimensions for the wing and stab tubes, and what is the thicknes of the balsa you cover the fuselage and wing with?
Vortex was designed for 22mm diameter wing tube and 11mm diameter stab tube, both available from F3A unlimited:
https://www.f3aunlimited.com/gator-7...ve-gc1001-2411
https://www.f3aunlimited.com/gator-c...ve-11mm-gs1009
The fuselage flat sides are covered with 3mm balsa, and the curved areas at the top and bottom with 2mm balsa.
