Originally Posted by
flywilly
Thanks for the info Alex, 2mm is the only size that I can't source.
The build looks great!
Thanks Will. Don't worry about the 2mm balsa, it is only used for the wing spar shear webs. You can use a slightly larger size without any problems if you are not worried about weight.
For the 2mm plywood, you can find 5/64 birch plywood here:
https://www.aircraftspruce.com/catal...nnishbirch.php
Alex
