Originally Posted by
Glowgeek
RE Loosy Goosy strut mount holes:
I used 4 or 5 coats of paste wax on the struts and JB Weld-ed my struts in on my 7 lb. P51. No problems after 60+ flights. I have not tried to remove them yet but I'm sure they'll come out.
Be aware that factory supplied struts are cut to length with a shear and are not round at the very ends. File them round otherwise you may never be able to remove them from the JB Weld.
Lonnie, I had a thought, what do you think, about using Gorilla Glue in the holes, it's tough and will foam around the wire, and would be easier to get in the holes ??
Jim
