RCU Forums - View Single Post - Vortex F3A build thread
Old 07-11-2019 | 01:28 AM
  #44
Alex Voicu
Originally Posted by bem
Hi Alex,
Great buld so far. What glue do You use in this build? I can see a bottle of Deluxe Materials "Aliphatic resin" wood glue in one of the photos - is that what You use?
/Bo
Thank you Bo. I only used aliphatic resin for attaching the balsa covering to the fuselage structure in the curved areas. It was supposed to be easier to sand but this is not entirely true
For the flat fuselage sides i used polyurethane glue (similar to Gorilla glue) because it fills the gaps and it is compatible with CA. If you wipe the PU glue with a tissue you can use CA to tack the balsa sheeting in place. You can't do that with epoxy and CA.
For the structure balsa parts i used CA in general, and for the parts where the loads are higher (like the motor mount and gear support) i used high strength epoxy and microbaloons.
Alex
flyinggazza (07-23-2021)
