Originally Posted by
drac1
I'm just saying what I would do if I had a standard 170 running 20% nitro. Performance depends on a lot of things. Airframe, altitude and flying style etc. But one prop doesn't suit everyone.
The 18.1 x 10 would give higher rpm and a bit less speed, but would give better climb performance.
That's only my opinion.
If you're happy with what you are are using though, keep going with it.
Interesting!! My only issue is there is a slight sluggishness on low end. I've contemplated modifying my throttle curve to compensate. Example is bottom of an outside loop maneuver I notice the need for more aggressive than normal throttle is needed to begin the upward half of the loop. I hate to think of a faster flying plane but I'll give it a try as I have a 18.1 x 10 handy.
Thanks!!
