Originally Posted by
PanzerBoy
In your second photo you have the engine deck vent which has the attachment bolt out of bottom attachs the deck to the hull.Is this a cast piece and if so where did you buy it and also are your idler wheels Taigen brand they list for a g but they also say panther A early[600] idler wheel.I have looked at the Heng Long version and seems like yours must be Taigen as they attach by a axle shaft.Thank you for your help
i'm sorry if i didnt answer this, the engine vent that holds the hull to the lower hull is stock, i just added some brass wire to make the "screen" and give the tank some more detail, the idler wheels are from Asiatam, they are for the D,A, and early G. You can find the idler at their site, they are not expensive and fit perfectly.
I hope this helps.
