Originally Posted by
Pylonracr
Cool, I have been using that resin for a while now and really like it. It does benefit from a post cure of 100 to 110F, especially if you use the slow catalyst. Did you figure the carbon gear out? I still need to order some fabric so let me know.
Scott
Sorry for the hijack Jester, you can have your thread back now......
Scott, nothing on the gear. I found an acceptable off the shelf solution and am going to stick with it. I would have liked to include them in the kit but multiple lengths are required depending on power used. A contra will require longer legs then single prop use.
