Utility floor:
Two spruce 'runners' were epoxied to each side of the fuse below the cockpit.
Removable fire wall installed to insure no interference with service panel, etc.
Some 1/4" thick lite ply screwed to the runners to support receiver, etc.
Inside of service panel door painted moss greeen.
Elevators.
HS-645's screwed into the stab.
Elevators installed into Robart pocket hinges. Everything is made modular.
Small hole in bottom of stab to access pocket hinge set screw.
End view of pocket hinge.
Servo covers installed and elevators checked via the transmitter and receiver.
Ball sockets on all connections and short linkages from servos to moving surfaces.
Button head screws to secure servo covers to stab.
Large holes needed as servo arm is short and allow room for ball sockets.
