Originally Posted by
Dalyn
While I was flying, my engine (Magnum XLS .46) suddenly surged to full throttle or so and then back to normal. It did it several times. Why does this happen?
because you say it went back to "normal" it sounds to me that your throttle servo is going bad, I have had a servo do that, also, check your Arm on the Carb, see if it's loose, see if your Carb is loose, if it is loose push down on it and tighten it up...
or, it could have been that your RX was not receiving the signal well while in flight ???
Jim
