Originally Posted by
Dalyn
Is there a way to tell if the servo is shot? Cause it's been working fine when it's on the ground and we're watching it...
I would try by loading the servo a bit with my finger, work the servo with the stick a bit/more than a few times, see if the servo holds up.
check your linkage, make sure it's not loose.
what type of radio do you have, a real cheap radio will have a weak transmitter and could give you trouble in areas with a lot of waves in the air, I don't know what else to tell you. maybe find a club near you and ask some one to take a look
Jim
