Originally Posted by
SA Flyer
Which 6-32 nut is more effective for firewalls, landing gear and such? From my last online order I received the smaller sized T-nut. Was expecting the type with the larger flange. Is the smaller flange size likely to fail or pull through later?
And, very nice work Vincent.
Lupe, always, always try to spread the load. So in your example if you have the room, opt for the one that has a larger diameter.
