RCU Forums - View Single Post - DLE20 - Throttle Problems
Old 08-20-2019 | 05:34 AM
kmeyers's Avatar
kmeyers
The bounty of knowledge says do not use a high speed or high torque digital metal gear servo on the throttle. Any high quality standard servo with nylon gears is better. If available use a throttle curve and never slam the throttle.
I'm hope you found and fixed your problem. I saw a similar case with a loose engine mount and broken firewall.
